Old 22-Oct-2013, 5:11 PM   #2
Pratical and Useful Information.
Install a Channel Master CM4228HD ,UHF/VHF antenna aimed at about 14 degree magnetic compass direction.
The CM4228HD is designed to receive the UHF channel band , channels 14 thru 51.
And the VHF channel band , 7 thru 13.
If required to improve reception.
Install a Winegard , LNA-200 'Boost' XT amplifier.
Installing the CM4228HD is better then installing a UHF only antenna design.
WGAL channel 8 should be received with the dual band CM4228HD.
If WGAL is not received well with the CM4228HD.
Then ->Also<-install a Antenna Craft Y10-7-13.
Aim the Y10-7-13 antenna at about 1 degree magnetic compass direction.
Use a UHF/VHF combiner , EU385CF-1s , www.solidsignal.com .
To combine the , CM4228HD and Y10-7-13 , antennas.
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.winegarddirect.com
Last edited by teleview; 23-Oct-2013 at 5:10 AM. Reason: Clarify Information and Typos.
