Old 22-Oct-2013, 4:34 PM   #7
Yes, try the amp. Set the switches to "Separate", connect to the UHF port, and set the FM trap to "On". Operate the slide switches with a small screwdriver or similar.
If you add the large antenna for KOLR, it will connect to the VHF port.
