My suggestion of the HD7698P is based on the fact that WVNY is broadcast on real CH-13, a High-VHF channel. The 7698 has intentional support for UHF and H-VHF reception designed into the antenna.
An alternate solution that would slightly exceed the single combination antenna's performance would be an Antennas Direct 91XG + Antennacraft Y10713 + RCA TVPRAMP1R.
The CM-5020 is close to the same level of performance, but includes the long elements needed for Low-VHF reception. I don't see that feature being of use to you at this time.
