Old 21-Oct-2013, 7:48 PM   #1
chambers
Best Pre-amp For This Setup
I am wondering if a pre-amp will help my situation, and if so, what the best one is for my setup.
The problem I'm trying to solve - there is a channel or two that will occasionally get pixelated and “stutter.” It isn't a big deal, but annoying enought that I want to eliminate it permanently. Will a pre-amp help?
My information:
  • Channel Master CM 4221A 4-Bay Bowtie Antenna, mounted in the rafters in my garage
  • I am 28 miles from the towers, all the local channels use the same tower farm
  • The channels I want are in the “green zone” for signal strength, based on the TVFool map tool
  • I am at the bottom of a hill, with the towers over the hill
  • I have a 50 ft run of quad shield coax from the antenna to the 3-way splitter
  • The splitter then feeds 3 tuners
chambers is offline   Reply With Quote
