Old 21-Oct-2013, 6:00 AM   #2
The 3020 would give a chance at seeing some signal from WWWB if it actually comes on the air. The signal is quite weak for that part of the L-VHF band. The signal from WTVF is even weaker, well bellow that typically needed for reliable reception of a L-VHF signal. Fortunately the signal on real CH-5 is a translator signal and the primary signal is broadcast on real CH-25 which has far less interference.
I would opt for an Antennas Direct DB8e + Antennacraft Y10713 + RCA TVPRAMP1R preamplifier which has separate inputs for UHF and VHF antennas.
