Old 20-Oct-2013, 7:33 AM   #2
StephanieS
Hi CJ28226,
Take the antenna outside on your roof and test it at magnetic 30 with a clear path to the transmitters.
You might find the problem solves itself.
Many around here aren't fans of attic installations for the reason that it really reduces signal strength arriving at your antenna due to passing through solid materials.
Originally Posted by CJ28226 View Post
Thanks in advance for the help. I have an RCA 751 antenna in my attic. I have my antenna aimed at 30 degrees of north. I can get all of the major network tv stations except for abc which is channel 9 and the tower is only 10 miles away. It always seems to just pulse in and out. I have about 70 feet of cable going from the antenna to the tv where it connects to my tv box.
Below is my report.
http://www.tvfool.com/?option=com_wr...46ae271af13771
Thanks again for any assistance you can provide.
