Thread: Lightning Fix
Old 9-Nov-2010, 8:34 PM   #3
jp2code
Ctrl+Alt+Delete
jp2code's Avatar
Could you clarify your answer, please?
You said, "First choice would be on the input to the pre-amp."
OK, which part of the "pre-amp system" are you calling the pre-amp, the device that mounts on the antenna mast or the electrical unit that plugs into the wall? Both pieces together comprise the pre-amp system, so I do not know how to interpret your answer.
Thanks for your help.
~Joe
Avoid Sears Home Improvement!
jp2code is offline   Reply With Quote
