Thanks for the input. I don't want to cause any problems for anyone, but at the same time I think I came up with a viable solution to my problem.
The tuner in the LG seems intelligent enough to be able to handle both types of signals on one line. During its scanning process it goes through DTV, TV(analog), CADTV(digital cable), and then CATV(analog cable) one right after the other and there is only one coax input. And like I said, I can choose which channels from all sources to be in a single combined lineup.
So with the tuner problem seemingly addressed, my only worry is the interference this may be causing via my antenna. Can the cable signal go up the other side of the combiner(and vice versa I suppose) and actually "broadcast" or am I concerned over nothing?
