Old 17-Oct-2013, 10:23 PM   #10
StephanieS
That is why I passed on it. The installation point at the back of the TV or at the end of the main drop came across to me much less effective than just buying a mast mount preamp and providing amplification where the signal is strongest instead of 150' later.
Once again, that amplifier is an indoor-only amplifier and is useless as a pre-amplifier. When used indoors, it may be used upstream of a splitter or long cable run or it may be put at the back of the set which is a generally useless location for an amp.
If you're putting it upstream of a splitter or long cable run, it's far more economical and effective to simply use a distribution amp.
