Practical and Useful Information.
As the Tv transmissions , channels/frequencies , travel across tops of hills and mountains , and Long lengths of miles and miles of ground , some not all , the signal/signals are bent downward because of the attraction of the ground and magnetic field of planet.
At different antenna heights channels/frequencies are effected differently , some are stronger and some are weaker.
So some Tv channels can be stronger a few inches to a few feet above ground.
The effect is known as ground wave reception and in some cases reliable reception does happen.
To take advantage of the effect at lower antenna heights it is also nessesary to also take into account obstructions such as buildings and trees and other obstructions that will negate the gain of signal strength.
Even so , here the Clear Truth , Ground Wave Reception Of Tv Transmissions is/are 100% Experimental.
Reason: Clarify information and typos.
