Old 16-Oct-2013, 10:30 PM   #13
Originally Posted by PJ_WI View Post
So if I pluged the antenna directly into the TV we would recieve 32? Currently are using the converter box.
Thanks,
The converter box is almost certain to block analog signals. If you turn it off, it may have 'analog pass-through'. If not, simply run the antenna lead directly to the TV for analog reception.
