Thread: Bad Reception
Old 9-Nov-2010, 2:54 PM   #4
magrau
Question Bad Reception
Thank you very much for your replies. Ok i have a one story one family house stuckle walls none metal roof my antenna is on a poll like 20 to 25 feet above ground this is my location ....
http://www.tvfool.com/?option=com_wr...81a3475a2d7472
and this is the type of antenna i am using .... HDTV Antenna with Motor Rotor, HD-2605
specs ....
Reception: VHF/UHF/FM
* Built-in Motor Rotor
* Dual TV Outputs
* Easy Installation
* High Sensitivity Reception
* Built-in Super Low Noise Amplifier
* Power Adpater and remote control included
* Coax cable included (4Ft x 1 and 40Ft x 1)
Frequency (VHF)
40 - 300MHz
Frequency (UHF)
470 -860MHz
Gain (VHF)
28 ~ 32dB
Gain (UHF)
32 ~ 36dB
Max Rotation
360 degrees
Power
3W
Impedance
75 ohm
DC input
15 ~ 19V
Demensions
22" x 30" x 4"
I am using two tv's with HD access boxes hope i answered everything. Thank you again for your support.
By the way I am getting 74 channels coming in and this mornig around 7:15 71 channels oppened right now is 9:55 and only like 10 channels are opening it stays like that all day until probably 7:30 pm when all the channels come back in.
magrau is offline   Reply With Quote
