Install a Winegard , LNA-100 'Boost' antenna system amplifier.
Once again, that amplifier is an indoor-only amplifier and is useless as a pre-amplifier. When used indoors, it may be used upstream of a splitter or long cable run or it may be put at the back of the set which is a generally useless location for an amp.
If you're putting it upstream of a splitter or long cable run, it's far more economical and effective to simply use a distribution amp.
