Old 15-Oct-2013, 5:27 AM   #2
Pratical and Useful Information.
Antenna setup for the Main groups of Digital Broadcast Tv stations/channels to the , South East , South , South West.
Above the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South West , South , South East and East.
Aim a Channel Master CM4228HD at about 180 degree magnetic compass direction.
For reception of Main Groups of Tv stations in the Green and Yellow reception zones a antenna system amplifier is not required because the signal strengths are strong.
Test reception of WBNS Real UHF channel 21 , virtual number 10 , CBS.
Aim the CM4228HD antenna at about 96 degree magnetic compass direction.
Scan for channels.
The signal strength of WBNS is very weak signal strength.
A Channel Master CM7778 preamplifier may be required for reliable reception of WBNS.
If reliable reception happens then leave the CM4229HD antenna aimed at WBNS and install a second CM4228HD aimed south for the Main Group of Tv stations.
Now this makes ->2 Separate antenna systems<-.
The 2 Separate antenna systems Are Not connected together onto one coax.
The 2 Separate antenna systems are in fact Separate All The Way to each Tv that WBNS is to be connected to a Tv.
A Remote control A/B antenna switch is used to change antenna systems at the locations that both antenna systems go to.
Use a , www.mcmelectronics.com , 32-4425 A/B antenna switch.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) chimney antenna mount.
Buy the ronard antenna mounts at , www.solidsignal.com or buy from , www.ronard.com
Here are se places to buy antennas at etc. .
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
Last edited by teleview; 16-Oct-2013 at 10:47 PM. Reason: Clarify information and typos.
