Old 14-Oct-2013, 9:29 PM   #2
The UHF antenna shown in your first thread may be a 'cut-channel' design, meaning it was optimized for a single channel. If that was the case, it would still make a pretty good UHF antenna but could have poor performance at particular frequencies.
Have you experimented with alternate locations that avoid trees?
Failing that, consider trying a Winegard HD7694P pointed at about 300°. It has more gain than your TVFR suggests is needed, but I see trees.
