ran coax straight from antenna to a TV, good reception all around. Reconnect to splitter, channels drop out. It is a three way splitter, only using two of the feeds so I think I'll go get a new 2 way with a wide range. When I put my preamp back in the mix it does not help. I suspect it is non functional. If a new splitter doesn't help I will be looking to get a new preamp. I do not know the path of all the coax in this house. It was run for cable TV long ago. It seems good quality with compression fittings although I crimped one of the ends myself. This cable provides good signal when run straight to the tV though.
