Old 13-Oct-2013, 10:54 PM   #11
laststraw
It sounds as if you are considering 'coax with messenger' which provides both support and grounding functions. The common size of the messenger is 17 AWG.
Thanks much for the reply - I've found your postings on grounding very helpful.
Bearing in mind that the cable already has the F-connectors, is it typical for the 'messenger' wire to be in a separate "sleeve" that can be peeled back from the coax outer covering for grounding? The picture doesn't show how the 'messenger' is integrated with the coax - and the reviews I read didn't shed any light on the issue - but that is the only way I can visualize it working.
When you use it, do you use the messenger to ground the mast as well as the coax itself? If so, what's the best way to do that?
laststraw is offline   Reply With Quote
