Old 13-Oct-2013, 10:41 PM   #9
voidcomp
Movement of an antenna in such conditions by mere inches can completely change the results.
That's for sure. When the antenna was moved there were times I pulled hardly any stations! The usual result is getting some at the expense of others. I'm generally happy with the compromise.
The acid test will come when I install a HDHomerun and see if signal strength remains strong enough to record. Unfortunately my Vizio has no signal strength function to give me a ballpark idea.
voidcomp is offline   Reply With Quote
