Old 12-Oct-2013, 6:36 PM   #10
Reliable reception from Tampa isn't very likely. It's further complicated by having four of their main stations operating on VHF which the Db4e wasn't designed for
Since you have the DB4e on hand, do give it your best shot. Be patient and be prepared to try multiple locations for the antenna to see if you can find a spot where everything falls into place and plays nice. If you're in the attic, moving the antenna by as little as 6 inches in any direction can affect the pattern or reception, so persistence is the key. If you go outside with the antenna, my best advice, in addition to the above, is do NOT drill any holes in your house until you've found a "sweet" spot.
