Old 12-Oct-2013, 3:49 PM   #4
Pratical and Useful Information.
For reception of the strong signal strength Tv stations to the , north , north west , west , east , and the weaker signal strength Tv stations to the south east.
Above the peak of the roof install a Winegard HD7694P antenna aimed at about 150 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim the HD7694P antenna.
A Winegard DS3000 J pole type antenna mount will work Ok with the HD7694P antenna.
Here are more antenna mounts.
www.ronard.com/909911.html
Use the , ronard (911) , 5 foot tripod antenna mount.
www.ronard.com/34424560.html
Use the , ronard (4560) eave antenna mount.
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard (2212) , ronard (2218) , ronard (2224) , chimney antenna mount.
Install All New RG-6 coax outside.
Use the RG-6 coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
Replace All connection hardware outside with New .
A antenna rotator is not required.
For 1 Tv connected use No splitter. No Antenna system amplifier.
For 2 Tv's connected use a simple common 2 way splitter. No antenna system amplifier.
www.solidsignal.com
www.amazon.com
www.winegarddirect.com
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on broadcast Tv reception.
Multi-path / Reflections , bouncing off the trees.
Absorbing and blocking reception.
The Best Pratice is to install the HD7694P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception in the directions of reception.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' ~ 'Antenna channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan or cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select 'Air Channels' ~ '
Antenna' channels'.
Scan for channels.
Last edited by teleview; 12-Oct-2013 at 8:46 PM. Reason: Clarify information and typos.
