Old 12-Oct-2013, 3:01 PM   #9
JefB
I have the DB4e now and will put it up soon. It does look like a well made antenna. Unfortunately, there is no place that would avoid the trees as they line the edge of the property on the NE side and are higher than the house. I'll try it in the attic and if it doesn't perform well enough there, I'll consider other options.
The stations towards 172 degrees are Spanish or limited programming so I'm not interested in them. If I could pull in the ones at 351 degrees and still get the locals at 30 degrees, that would be great. But those are 90 miles away and so, I assume, are beyond range. Is it worth trying that direction or would it just be a waste of time? It is clear of the trees that direction.
Thanks for all your help,
Jef
JefB is offline   Reply With Quote
