It sounds as if the old antenna may be worn out. And you've shown that indoor reception is less than reliable.
Consider replacing the outdoor antenna with an RCA ANT-751R pointed NW. Be sure to use new cable outside so that there are no unneeded splices and all of the cable is a 'known quantity'.
Avoid aiming through trees or buildings if at all possible.
