Okay, I can pick up the Fox channel to the south with the SR15.
But, seems I have a problem. I can't get the signal from the SR15 antenna to go through the splitter I'm using to join the antennas. Works fine hooked directly to the box.
The DB8 works fine hooked directly to the box or singularly to the splitter.
The signal from the DB8 goes through the splitter fine, with or without the SR15 hooked in.
I thought it might be a problem with combining the two antennas, but the signal from the SR15 won't go through even when I disconnect the DB8.
Right now, the SR15 just lying on the deck and getting fair reception of most channels. The exception being CBS with is VHF.
I'm wondering if I jumped the gun buying the SR15.
Isn't the DB8 a stronger antenna?
I'm thinking I should have just gone up and turned it south instead of listening to the tech from the local Fox station that advised me to buy the SR15.
