Dense forest signal path plus attic location = erratic reception for UHF stations.
Most likely, the antenna is simply in a "dead" spot for that particular station. On UHF stations, such spots can be as small as 6-12" Try multiple antenna locations to see if you can find a single spot were everything plays nice. Then, if necessary, move the antenna to the outside and up in the air.
