Old 11-Oct-2013, 6:13 PM   #2
W42CX is unbuilt. WNJJ, as of Jan 2011, was broadcasting infomercials. Who knows if it's still on the air?
If you want reliable reception, forget all the little flat antennas, especially those for indoor use. Your TVFool plot indicates you need something substantial on the roof with a proper pre-amplifier. Unless you are content with stations from a single direction, a rotor is also recommended.
Plan on either a single 10-14' long antenna or two smaller antennas mounted several feet apart on a single mast.
