You can get all of your local Columbus stations with a simple small antenna such as a DB2e or a ClearStream 2. There's nothing operating within range on any VHF station and no need for a 10' long combo antenna that's been discontinued.
Dayton is possible with a larger antenna such as a DB8 plus (probably) a rotor and a good pre-amp
A lot is going to depend on how clean the signal paths are from your proposed mounting location.
