Thanks for the reply.
You mentioned possibly raising the antenna above the roof peak, our HOA doesn't permit aerial antenna's other than sat dishs. So this will have to stay in the attic. I would LOVE to pull in CBC 9 for hockey games.
Is there a solution that can help without mounting on the roof?
Also, I should have mentioned that the 3 tv's runs from the distribution box are probably 30-50 ft each, even though it's a 30ft run from the attic to the box.
Will that booster be enough to split the signal 3 ways?
Thanks again.
