Old 11-Oct-2013, 12:07 AM   #2
Pratical and Useful Inforamation.
For reception of ->Many<- USA Digital Broadcast Tv stations/channels.
Start with a Antenna Craft HBU44 antenna in the attic aimed at about 130 degree magnetic compass direction.
_______________
Install a Winegard LNA-100 'Boost' antenna system amplifier.
_______________
If reception situations/issues are happening that are not resolvable by adjusting aim and location of the HBU44 antenna in the attic then move the HBU44 antenna to above the peak of the roof.
_______________
The tvfool report is showing that 2 Local reception Canada Digital Broadcast Tv stations/channels are receivable at your location.
CBET-DT channel 9 , The CBC.
CICO-DT channel 32 , TVO , Canada's PBS.
The Canada Tv stations are Weak signal strength.
If the Canada Tv stations are not received with the HBU44 antenna in the attic then move the HBU44 antenna to above the peak of the roof.
The HBU44 antenna is aimed at about 130 degree magnetic compass direction.
______________
http://www.solidsignal.com.
http://www.amazon.com
http://www.antennacraft.net.
______________
Last edited by teleview; 11-Oct-2013 at 3:43 AM. Reason: Clarify information and typos.
