Old 10-Oct-2013, 11:28 PM   #2
Practical and Useful Information.
A Simple Reception Situation.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East , North East , South East , West , South West.
Install a Winegard HD7696P antenna aimed at about , 86 degree magnetic compass direction.
_________
Use the , ronard(911) , 5 foot antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , http://www.solidsignal.com , or , buy from http://www.ronard.com.
______________
http://www.solidsignal.com.
http://www.amazon.com.
_______________
For 1 Tv connected use No splitter. No antenna system amplifier.
For 2 Tv's connected use a simple common 2 way splitter. No antenna system amplifier.
_______________
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception.
Multi-path reflections signals bouncing around.
Reducing and blocking reception in the directions of reception.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
_______
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' ~ 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
___________________
Cable Tv service , cable delivered internet service , cable deliverd phone service <-> Can Not Be Connected <-> to any coaxes that are being used for and are part of the antenna system coaxes.
Any type or kind of cable deliverd service must be on a separate coax.
___________
Last edited by teleview; 10-Oct-2013 at 11:30 PM. Reason: Clarify information and typos.
