The Current Plus Pending Applications Included Digital Tvfool radar map and channel list shows the the Main Group of Digital Broadcast Tv stations is/are to the , North East / East , with a few to the , North West.
Many of the Tv reception stations/channles are Strong Signal Strength at your location.
Low Signal strength at your location is not the problem.
The problem at your current reception location is Strong Signal Multi-Path Reflections bouncing all around.
Digital Broadcast Tv tuners can correct multi-path up to a point and can correct strong signal strength multi-path up to a point , and then the Tuner is Over Loaded.
A over loaded tuner will fail to tune some channels.
Recommend switch off the amplifier of the HDTVa antenna.
-->The HDTVa Must Remain pluged in to the electric power.<--
With the HDTVa pluged in and the switch of the HDTVa in the off position , The HDTVa will be a Non amplified antenna.
A Non amplified antenna will not be amplifing the Multi-Path Reflections.
This will improve reception.
Do a Double Rescan.
_______________________
Your problem is no clear obstruction free reception to the , North East / East.
The more obstructions that are in the way of reception , the worse reception will be.
_____________
Recommend move to a apartment that has a clear view or improved view to the , North East / East.
_____________
If can not do that then is there a window or patio door window to the North East / East , that can put the HDTVa antenna in??
_____________
If can not do that then is there any way to install a ANT751 antenna at a outside location that will provided a better view to the North East / East.
_____________
A question that helps with expandad thinking.
Are there any of those small satellite dishes on the outside of the building or on the roof of the building??
And if so , then the coax of the small dishes will most likely be going through the outside wall to inside of the apartment.
If so then , most likely you can install the Small ANT751 Antenna , also on the outside of the building / roof.
-->Remember the following fact.<--
-->The More Clear the view to the North East / East the antenna has , the better the reception will be.<--
_____________
Reason: Clarify information and typos.
