Old 10-Oct-2013, 6:24 PM   #1
Fignewton
Antenna/Equipment Recommendations in Michigan
http://www.tvfool.com/?option=com_wr...46aefd68f925c3
Moving into a new construction home and looking to cut the cord. I would like to have the antenna in the attic, I had coax ran and an outlet installed in the attic (for a potential pre-amp) more than enough room up there, but I'm now limited to accessing through normal sized access panels.
I've read things about the ClearStream 4, but I have no idea on possible antenna choices.
The coax runs from the attic to the basement (i'm guessing 30ft.) distribution/termination box. I would like to feed 3 tv's from there. Do I need a pre-amp or a distribution amplifier?
Thanks in advance for any advice.
Fignewton is offline   Reply With Quote
