Old 9-Oct-2013, 8:17 PM   #2
The signal strength of WPXA-DT Real UHF channel 51 is Very Low Signal Strength at , minus -4.8 NM(dB) and has 2 Path obstruction and is 47.8 miles away.
Will most likely not be received with any type or kind or size of antenna in the attic.
Recommend install a Winegard HD9095P UHF antenna above the roof so the roof and building are not obstructing reception in the direction of WPXA.
Try a Winegard CC7870 , Isolation Transformer Type Combiner to combine the HD9095P UHF antenna and Y10-7-13 VHF antenna.
Isolation transformer type combiners , the inputs and output are decoupled with transformers , this reduces antenna cross talk and signal strength bleed off of one antenna to the other antenna.
_____________
Another way to do it is use a Remote Control A/B antenna switch with seperate coax runs to the Tv locations.
http://www.mcmelectronics.com. Part number , 34-4425 .
_________
http://www.solidsignal.com.
http://www.amazon.com.
Last edited by teleview; 9-Oct-2013 at 8:20 PM. Reason: Clarify information and typos.
