I will try raising the antenna first.
I can probably go about 4 feet and replace the existing coax.
I have the tools for cutting/prep/and crimping along with good barrel outdoor type connectors.
But i will need to solder splice and put water tight shrink on the rotor cable to get enough length. I believe splicing it shouldn't be an issue.
