Old 9-Oct-2013, 4:42 AM   #5
Antennas Direct also offers power passing splitters: http://www.antennasdirect.com/store/splitters.html
The PA-18, like virtually all preamplifiers is powered by low voltage inserted into the coax. The power supply and power insertion block are intended to be indoors. You will need to have an extremely long cable run to before you need to worry about voltage drop.
