Most of the receivable Digital Broadcast Tv stations/channels are Very Weak Signal Strength at your location.
I recommend stay with Big 3036 antenna.
Or can install a Winegard HD7084P or a Winegard HD7698P antenna.
The tvfool radar report and channel list shows that the report is resolved to block level.
The reception is most likely better then what the tvfool report says because your actual location is at a better reception location.
This then is a example of the reason that is important to make a accurate tvfool report so one can better know what is receivable.
Reason: Clarify information and typos.
