Your problem with 27.1 is that WFXR shares channel 17 with WNCN. WNCN is predicted to be 5.4 db stronger than WFXR. In order to pick up WFXR you will need an antenna with roughly 25 db rejection of WNCN. To do so would take a pair of identical antennas such as the 43XG or 91XG stacked horizontally with an exact spacing of 29 inches. You can read about ganging antennas at hdtvprimer.com/ganging
