For reception of ,
WNLO-DT CW.
WNED-DT PBS.
WIVB-DT CBS.
WUTV-DT FOX.
WKBW-DT ABC.
WGRZ-DT NBC.
WNYO-TV MyNetwork.
You can Test reception with a Winegard HD7696P antenna mount above the roof in the same manner as the HD7698P antenna.
Aimed the Same Direction.
A tripod type antenna mount can be set on the roof and moved around if required to find the best location fo reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
As allways , the starting antenna aim direction is the --> strarting antenna aim direction.
The antenna Aim and antenna location can be adjusted for best reception.
_______
For 1 Tv connected , No splitters.
Test reception without a antenna system amplifier.
For more then 1 Tv connected , Use a Winegard LNA-200 'Boost" XT amplifier.
_________
Reason: Clarify information and typos.
