I presume the PA-18 needs to be located up by the antenna. With that said, I have a couple of RG-6 runs on the roof. I will be using one of those for the antenna. The location to power the PA-18 is about 30 feet away as well (the other RG-6 run). What I am asking is can I power the PA-18 from one of the 30 foot cable runs? I have no way to get power close to the antenna location. Also, can I use a regular splitter at the splitter location (also 30 feet away from the antenna) to get to the two TV locations versus an amp/powered splitter.
Thank you.
