Let the 3036 run a few days... Through some wet and windy weather if possible. If reception remains reliable, great... If not, that confirms going smaller is not going to be a good plan.
I might suggest the DB8e if smaller is mandatory.
None of the UHF only antennas are going to do well with VHF signals, though Channel Master bills the CM-4228 as having some VHF capability. You may find yourself needing to add an Antennacraft Y5713 or even Y10713 to make WENH reliable. I would try a UHF only antenna by itself, then decide if the signals from real CH-9 & CH-11 are needed/wanted.
