Consider the Clear Stream 5. It was designed as a High-VHF solution but has proved to have useful UHF performance as well. http://www.antennasdirect.com/cmss_f...with%20uhf.pdf
The VHF performance is directional, face the antenna toward 47° (mag.). The UHF performance is less directional, approaching omnidirectional. (See page 8 of the manufacturer's technical specifications.)
To answer your question more directly, the C2V is more appropriate than the Mohu in your situation.
Reason: sp.
