While it's possible you may see WMC, the odds are against you. The signal levels are quite low and Low-VHF antennas are not going to have the gain needed to make that signal reliable. I'd say try if there was no other NBC option.
KFVS appears to be your one CBS option so I would point an Antennacraft Y10713 at it.
Combine the 91XG and Y10713 with a UVSJ (UHF / VHF signal combiner)
