Old 7-Oct-2013, 8:25 PM   #2
The ANT-751R is a very good antenna in situations with stronger signal levels. Most of the signals available to you are too weak to make the ANT-751R and good recommendation.
You'll need a large high gain antenna mounted in a location that's not blocked by trees. Most signals are UHF, but you also have a few High-VHF signals.
I'd consider using an Antennas Direct DB8e, Antennacraft Y10713 and an RCA TVPRAMP1R preamplifier.
If you're down in the trees with no way to get over or around them, your results are going to be affected adversely.
