Old 7-Oct-2013, 12:06 PM   #34
No static at all
No static at all's Avatar
Excellent, you sold that Stacker faster than expected!!
If you do decide to go with the 7698, keep the mast length 5 feet or less above the rotor. Mount the 7698 no more than 1-2 inches above the rotor to help keep the torque loading to a minimum. The recommended mast length is usually 3 feet or less with light duty consumer grade rotors as they cannot withstand twisting forces like a heavier duty rotor can.
Have you considered a tripod or chimney mount? Not sure if that eave mount will be able to handle the extra load?
