Old 7-Oct-2013, 11:43 AM   #9
Choice 1 is a single antenna: Winegard HD7698P
Choice 2 is two antennas. It will work better on UHF, but cost more and be more complicated:
UHF 91XG
VHF Y10-7-13
Combine them using a UVSJ
Both are good options, I lean toward option 2... It makes the most of your chances at seeing the Fox affiliate WFFF. The path profile of WFFF makes me wonder if mounting a bit higher would change your signal conditions significantly.
A TV Fool report based on 25' or 30' would be interesting to look at.
