Old 6-Oct-2013, 7:45 AM   #25
skatingrocker17
A test I did to compare 1 antenna vs. 2 is tune to channel 11.1 (real channel 11). With two FM6s connected the signal strength was 72%, with one connected (the higher one), the signal strength was 92%.
Is this a good indicator on whether I should use 1 or 2? I know channel 11 is VHF-high whereas FM would be low band.
skatingrocker17 is offline   Reply With Quote
