Old 8-Nov-2010, 2:56 AM   #4
Phoenix42
Thanks GroundUrMast and Tower Guy, you've narrowed down the range greatly.
Now I just need to understand the differences between 4bays and 8bays - from what little I understand more bays equals more signal pulled in, but if I limit myself to channels in the yellow range how much signal do I need to pull in?
From an install point of view, can I leverage an old satellite dish roof mount, and attach a short mast to it to support an antenna?
I assume if I add in a Y5-7-13 VHF that the two antennas should be a certain distance at minimum apart, what is the rule of thumb on this? Also, it would be pointing right at my neighbors house (std wooden construction) - would this be futile?
Again, thanks.
Phoenix42 is offline   Reply With Quote
