Old 5-Oct-2013, 11:56 PM   #2
The Main Group of Tv stations is to the West.
For a indoor type antenna install a Terk HDTVi (not HDTVa) antenna in/at the North West facing window Up High in/at the window.
If a long continues length of coax is required to connect the HDTVi antenna that is in the North West facing window to the Tv and the long continues length of coax runs through the Apartment to do it.
Then So Be It.
You can also try reception with the HDTVi antenna on a West facing wall , Up High will most likey provide the best reception.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
You can try a Winegard , LNA-100 'Boost' amplifier to improve reception.
http://www.solidsignal.com.
http://www.amazon.com.
___________________
Here are some Tv guides.
http://www.zap2it.com.
http://www.titantv.com.
____________
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan.
http://www.wchstv.com/DoubleReSacanAlert.pdf.
_______________
Last edited by teleview; 5-Oct-2013 at 11:59 PM. Reason: Clarify information and typos.
