Old 5-Oct-2013, 10:34 PM   #3
The Current Broadcast Tv stations/channels in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable channels in the VHF high band and UHF band.
Recommend install a Channel Master CM4228HD , UHF/VHF high band antenna aimed at about 92 degree magnetic compass direction.
Your location has receivable broadcast Tv stations in the directions of , East , South East , South , South West , West , North West , North , North East.
The Best Pratice is to install the CM4228HD antenna at a location that has the least amount to no amount of obstructions of any type or kind in all of the directions.
________________
Install a Channel Master CM7778 preamp.
________________
Buy the HFS splitters at , http://www.solidsignal.com.
________________
A Winegard DS3000 J pole type antenna mount works Ok with the CM4228HD antenna.
Here sre some more antenna mounts.
Use the , ronard(4560) , eave antenna
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , http://www,solidsignal.com , or buy from , http://www.ronard.com.
___________________
Here are some places to buy antennas ans etc. .
http://www.amazon.com.
http://www.winegarddirect.com
___________________
Use the CM4228HD antenna to test reception of 2 Canada Digital Broadcast Tv stations/channels.
http://en.wikipedia.org/wiki/CBFT-DT.
http://www.en.wikipedia.org/wiki/CBMT-DT.
To Test reception , turn the antenna by hand to about 360 degree magnetic compass direction.
Rescan for channels.
__________________________________
Digital broadcast Tv tuners can develop - Digital Glitchs - that are not cleared out with simple channel scans.
Do Double Rescan , http://www.wchstv.com/DoubleReScanAlert.pdf.
If Canada channels are received and will like to continue to receive Canada channels.
Install a Second antenna system that is the same as the first antenna system.
The 2 antenna systems are 2 Complete Separate antenna systems , that Are Not connected together.
A remote control A/B antenna switch is used to select antenna systems.
A/B Antenna Switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
http://www.mcmelectronics.cm.
Remote control A/B antenna switch , 32-4425.
More information.
WCFE-DT channel 38 , http://en.wikipedia.org/wiki/WCFE-DT , is strong signal strength and will be received through the back of the CM4228HD antenna.
When the antenna is aimed at about 92 degree magnetic compass direction.
W46ED-D 46 and W25BT-D 25 , Repeater transmitters , are the same as WCFE-DT 38.
Last edited by teleview; 5-Oct-2013 at 10:41 PM. Reason: Clarify information and typos.
