Old 5-Oct-2013, 10:31 PM   #1
tally
Recommendation for Antenna Please
Please see the referenced signal analysis report:
http://www.tvfool.com/?option=com_wr...46ae3546732a8d
I am interested in an antenna setup that can pickup the most channels - primarily the major networks that are location south of my home.
I am in a very wooded area so there will be trees but not within in a 100 feet of the antenna location; but the antenna will not be able to exceed the height of most trees in the area. The antenna will be on the roof approximately 20 to 25 feet off the ground. The signal needs to reach two TVs. The cable runs are approximately 20 and 40 feet respectively to each set (from the antenna).
Please recommend a setup (antenna, boosters, etc) that will work for this situation.
Thanks.
tally is offline   Reply With Quote
