Old 5-Oct-2013, 5:01 PM   #6
Stereocraig
Originally Posted by protivakid View Post
Alright so after using the multimeter again I got my rotator moving. The small motor was frozen but I was able to get it going again. The rest of the gears still moved fine.
Questions:
What type of grease can I use to lube up the gears some? Will something like automotive wheel bearing grease work?
Any idea where I can find a rubber gasket for the top seal of the rotator housing? The old one is junk
Yeah, I just use the grease gun and spread it w/ a blade screwdriver. It doesn,t hurt to do the bearing right under the rubber boot, too.
I've seen where that pipe clamp gets oxide powder buildup.
UV really takes it's toll on those rubber boots.
I have one I thought about repairing, but it feels like another crack, may not be too far in the future.
Something would need to be fabricated, or you'd need to find a parts unit, cause CM does not offer them.
